It is currently Tue Aug 25, 2026 10:22 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: I knew it! MY car is a PIG!
PostPosted: Thu May 08, 2003 1:23 pm
1660Kilos! That's 3652lbs w/ a empty tank of gas and me NOT in it. I'm only 145 but me and a full tank I'm pushing 3800lbs +! (*&^*!@ PIG!
Well at least I know what I weigh and that's w/ lighter seats, lighter upper and lower A-arms, tubular arms out back sub frames no rear seats AC, Air pump, EGR. Maybe I'll do the k-member after all rip the carpet out and remove the air bags.
DAMN!!!!!! :evil:
Well according to GM you subtract the 680lbs from the GVWR weight listed on the door. 4 passengers @ 170lbs X 4 = 680 so that puts me @ 3533 curb weight.
I can live w/ that. :D
 Post subject: Re: I knew it! MY car is a PIG!
PostPosted: Thu May 08, 2003 1:30 pm
DAMN!!!!!! :evil:
Dude that is nothing compared to my 4200lb paper weight. I've also added the SSM subframe connectors and lift arm system. She probably weights about 4350 now. Time to start shedding some weight.
Best 1/4: 13.587 @100.90mph
PostPosted: Thu May 08, 2003 1:35 pm
Man why couldn't we just start out a 3400lbs max? Then we could work our way down.
Hell I think 911's weigh around 2500 or so. Imagine us being that light w/ all that engine to back it up? My next car will definetly be a light import like a s2000 and slap a turbo on it.
Mike's 2nd gen weighed 1610 kilos. That car is huge and weighs less than mine.
PostPosted: Thu May 08, 2003 1:42 pm
That does suck. Don't know why ours are so heavy. You are right, if we had the same hp in a 2500lb car then there would be 9 second time slips waving around.
PostPosted: Thu May 08, 2003 2:36 pm
Why are you so heavy? I just looked at the SLP Birth Certificate for my car and it gives the weight as 3439 and it's a vert. I know the engine is lighter but it shouldn't be that much lighter. Your's sounds really heavy.
 Post subject: WTF?
PostPosted: Thu May 08, 2003 2:45 pm
WTF?
Mine weighs in at 1653 with T-Tops and all loaded.
R@M and still it ran only 13.9 on the quarter....
Got boost?
PostPosted: Thu May 08, 2003 3:06 pm
I don't know Dino. But you can have to exact same cars w/ the same options and everything and you'll see a difference in weight vary from anywhere to 100-250lbs. Now that's a WTF type question there. Seen it w/ my own eyes back in the states.
PostPosted: Thu May 08, 2003 3:24 pm
1660kg?! Remove the camping trailer from your trailer hitch! ;)
Only 1450kilos here. And 2 cylinders less. :roll:
PostPosted: Thu May 08, 2003 5:22 pm
My R5 weighs only 800 kilos, LOL. :lol:
PostPosted: Thu May 08, 2003 9:35 pm
I know what it is... somebody is watchin' out for you and at night filling up the car with extra weight,
to make sure you do not kill yourself with all the hp and speed...
back years ago they had to build hp to move the weight, and now they put weight on to calm the hp. :shock:
ok do only believe this if you believe in angels. :wink:
PostPosted: Thu May 08, 2003 10:17 pm
My '57 Chevy truck weighs in at 1700 kilos. Thats with a 350, REAL steel, full frame, lots of sound deadening, and even a hitch! OK, I don't have all of that emisions crap :twisted: or ac, but I had no idea that it only weighs a little more than a Camaro :dunno: After the stereo install it'll weigh more, but I do plan on making it lighter. I'll start by removing about 150 pounds of bondo...
PostPosted: Wed May 14, 2003 12:07 pm
Volker has gotten his Z28 down to 1390 kilos.. That is phenomenal... ;) Of course, he doesn't have anything on the interior, but still! :shock:
 Post subject: Hate to throw my weight around!
PostPosted: Wed May 14, 2003 1:19 pm
:D 1977 Kilos or 4350 pounds without my heavy butt!
Mav
PostPosted: Wed May 14, 2003 7:28 pm
my Z weigh's 3085. w/o me in it and like almost no gas.
Will
coming to Germany in oct.
Mods wont all fit so: GMPP, Edelbrock, Hooker, MSD, Auburn, Auto Meter, Nordskog, B&M, Harwood 4" cowl, and SFC's
PostPosted: Wed May 14, 2003 8:06 pm
Wow, Will, that is pretty light man. Do you race?
PostPosted: Thu May 15, 2003 1:14 am
I race a little bit :D , car should be faster than it is though, I think it's the suspension's fault.
Will
PostPosted: Thu May 15, 2003 4:54 am
so how quick is it? nice hood.
PostPosted: Thu May 15, 2003 8:01 am
thanks, I love the hood, it's a good conversation piece, LOL
Well, here come the excuses, my best is a 13.8@101 2.2 60ft here in phoenix. Since then I did an Edelbrock RPM Air Gap intake man. and a 2" phenolic carb spacer(main reason for the hood, plus allows for a blower later on), I got the carb tuned a little better, and added some sub-frame connectors. I noticed I am only getting around 5 1/2 psi fuel pressure to the carb so I aquired a holley "red" elec. fuel pump to put in, I am just a lazy ass and havent completely installed it yet. I am getting some BFG comp T/A drag radials and finishing the F/P install before I go to the track next friday (23rd). I am hoping to knock out at least a low 13 sec ET, but we will see. after that, N20 is going on, unless I decide to do a better set of heads and a bigger cam, all depends on the money situation.
Will
 Post subject: Re: Hate to throw my weight around!
PostPosted: Thu May 15, 2003 9:19 pm
Mav
:shock: :shock: :shock: I didn't know that SS Imps had an armor plating option! :wink: And I thought my truck was heavy...
PostPosted: Fri May 16, 2003 7:20 am
sounds like a mustang eater LOL 80 killer I plan to crush you soon. that is as soon as I get it running again.
