It is currently Tue Aug 25, 2026 11:15 am
 Post subject: No water in oil....
PostPosted: Wed Jul 09, 2003 8:55 pm
What is the best way to ensure that there is NO more water in the oil? Do I just drain the oil, or are more grueling steps needed??
PostPosted: Wed Jul 09, 2003 9:18 pm
Just draining the oil should be OK. There might be a slight amount, but it won't be enough to hurt anything.
PostPosted: Thu Jul 10, 2003 5:36 am
change oil and you will be fine how did the head studs work?
PostPosted: Thu Jul 10, 2003 3:25 pm
If it makes you feel any better, oil floats on top of water so when draining, the water will be the first out of the pan. After the oil has been drained, (and refilled!) just run the car till it gets to normal operating temperature for a while. The heat will cause any remaining water/condensation to evaporate.
PostPosted: Fri Jul 11, 2003 5:56 am
Thanks fellas! ;)
