It is currently Tue Aug 25, 2026 4:55 pm
 Post subject: Calibrating needles
PostPosted: Tue Dec 30, 2003 8:38 am
Anyone know how to do this? I installed my gauges last year, but the needles are all screwed up.. Does Aafes do this? I'd really love to have functioning gauges.
PostPosted: Tue Dec 30, 2003 8:51 am
i can :lol:
1994 t/a
PostPosted: Tue Dec 30, 2003 4:22 pm
Jack if you got Atap or ls1 edit. u can use that to get your needles close on the all the guages . Just leave the plastic off and hook the connector back in the guage cluster. Bring engine to op temp and set the your temp , bring up voltage , tach and what ever else and readjust the needles as close to the values as possible. for the speedo put the back axle on jackstands , and use yor cruise control and edit to monitor your speed and then adjust your needle.
It worked for a couple of friends over here .
PostPosted: Tue Dec 30, 2003 4:31 pm
How can I do that with LS1Edit? I'd love to know.
PostPosted: Tue Dec 30, 2003 4:41 pm
jack u wil have to move the needles manually , but Iam under the impression that edit will let u see all your vehicle vitals on your laptop. I may be mistaken, I know Atap does .
PostPosted: Tue Dec 30, 2003 4:57 pm
Unfortunately, I don't believe it does. It only allows you to change most parameters.
PostPosted: Tue Dec 30, 2003 9:09 pm
jack ican set those needles for you they will be close enough
1994 t/a
PostPosted: Tue Dec 30, 2003 9:27 pm
No offense, but I don't want someone to eyeball them. I want them to be dead-on accurate!
PostPosted: Tue Dec 30, 2003 9:31 pm
uh mine ar accurate i di my guages also
1994 t/a
