Joined: Sun Dec 21, 2003 6:11 am Posts: 228 Location: fayettenam, nc
I was considering putting a shift kit in my car and just wanted get some more opinions on wether or not I should or basically what you guys think about it. If your for it any advice on where to go to get one? Thanks
Go with the Trans-go. Too many complaints with the B&M and the "electronic" ones will cause problems down the road. All they do is up the fluid pressure all the time which will blow seals.
$110? from summit. Check out other tranny sites for better servos. They provide more fluid pressure to the clutches when you need it and they can be replaced with the tranny in the car and without dropping the pan. Just something to think about...
Thank you for all your help but I do have another question if you guys dont mind this is going sound real stupid but can I still put one in even if I have an automatic tranny or does that pose a problem
