It is currently Tue Aug 25, 2026 8:33 am
 Post subject: Yeah my SS is here, but..............
PostPosted: Fri Oct 26, 2007 8:22 pm
The freakin thing won't start. First the battery was extremely dead and would not jump. So, I went and got a new one. Now it will crank , but it won't start. I checked fuel pressure and had about 52PSI at the rail. Then used a plug tester and got clean spark. That tells me the injectors must not be firing. BOA279 suggested I clean the VATS connections both in the cylinder and on the key. I cleaned buth, but it still won't start. Any ideas? I have to get it out of the storage area TOMORROW!
Brian
PostPosted: Fri Oct 26, 2007 8:26 pm
Are you getting any SES light or similar?
PostPosted: Fri Oct 26, 2007 8:28 pm
The light is staying on, but I am sure it is because it is only cranking and won't start.
Oil pressure kicks up to 60 and volts are steady.
PostPosted: Sat Oct 27, 2007 8:27 am
Any ideas? I am heading there in about an hour.
PostPosted: Sat Oct 27, 2007 8:31 am
Hm ... reading the code might help ... or scanning some motor info during crank ...
PostPosted: Sat Oct 27, 2007 8:46 am
Garry, I would love to read codes, but I just got the car yesterday and don't have a scanner yet. I bought it site unseen and had it shipped from the states....believe it or not.
If ANYONE would like to help today, I will be out at the car in Ramstein Meisenbach. Give me a call at 01511-869-4133.
I am also looking for someone to help tow it. I do not have any equipment for that other than a truck.
Thanks
Brian
PostPosted: Sat Oct 27, 2007 9:12 am
I'm about 2 3/4 hours away, which doesn't really help (plus on 24/7 duty) ... maybe you can ask Roy if he can check the trouble codes?
PostPosted: Sat Oct 27, 2007 9:30 am
I have only met him once so I don't have any of his contact information. Hopefully he will chime in here and give me a call. That is exactly what I need at this point.
PostPosted: Sat Oct 27, 2007 5:57 pm
Some simple stuff
Check INJ1 and INJ2 fuses . If they are good disconnect the battery for a min of 30 seconds . reconnect and try .
If it still doesn't pull the two 168 pin connectors and look for corrosion .
PostPosted: Sat Oct 27, 2007 7:26 pm
Thanks for all the suggestions.
We got it all figured out tonight. Everyone of the plugs were fouled out. I am hoping it wasn't from something that was done during the shipping. My theory is that when I was trying to get it started with the dead battery the injectors were firing, but the plugs could not causing a very lean condition and fouling them out.
Thanks Silas for the plugs.
The beast is ALIVE!!!!!!!!
PostPosted: Sat Oct 27, 2007 7:40 pm
Congrats, glad to hear ... think you can make it to the NHRA folks event in November?
PostPosted: Sun Oct 28, 2007 5:32 am
:evil: Brian :evil:
U SUCK......
no really, glad you got it runningl, now if I can just have the same luck tomarrow all will be good......
I thought I was suposed to loose sleep after the kid gets here not before...I want to be a Kapuan as soon as they open.
If you get this today before noon stop by so i can see the ride......Im on R8 after 12 till quitin time.......good 'ol FRED screwing me over again....
jamie
