It is currently Tue Aug 25, 2026 5:10 am
 Post subject: Parts FS
PostPosted: Sun Oct 13, 2002 7:53 pm
JVC digital camera. 3.3 megapixels- $400 (I paid $699 last year) I used this camera to take most of the pics on my site..
Stock rotors and pads with less than 1000 miles on them. No warps or cracks. $80 for set obo..
Stock master cylinder. Best offer.
Stock exhaust manifolds. Best offer.
Stock y-pipe with cats. Best offer.
Dunlop SP8000 with about 2000 miles. 95% tread left. Best offer.
Thunder Racing red anodized MAF ends. $80 obo
PostPosted: Mon Oct 14, 2002 8:08 am
Do they fit a 98 V6? Tony said something when I was down there for the sway bars that the pads on mine were down pretty far ...
Size?
PostPosted: Mon Oct 14, 2002 4:57 pm
I don't think the rotors and pads will fit, but if you find out they will, you can have them. The tire is 245/50/16
PostPosted: Mon Oct 14, 2002 5:22 pm
Think they will fit an 88 (if needed)?
NovaRat
Size Does Matter!!!
PostPosted: Mon Oct 14, 2002 5:41 pm
They will fit a 98 or newer fbody no problem.
PostPosted: Mon Oct 14, 2002 5:46 pm
Oh yeah, I forgot he has a '98... :) Garry, do you want them?
PostPosted: Mon Oct 14, 2002 7:42 pm
Just checking whether they will fit over at the other fbody site ... if they fit, I'll take 'em ...
Btw, what model is that camera?
PostPosted: Mon Oct 14, 2002 7:50 pm
It is the GC-QX3
PostPosted: Mon Oct 14, 2002 9:03 pm
It is the GC-QX3
Anything behind the "3"? ;) Trying to find some info on it ...
PostPosted: Mon Oct 14, 2002 9:36 pm
Sorry, I lied. It is the JVC GCQX5HD
3.34 MegaPixel CCD with RGB Color Filter
200,000-pixel TFT Polycrystlline Silicon Color LCD
Built-in Auto Flash with red-eye reduction
Hi-Contrast 2.3x Zoom Lens
6 Megapixel Pro-Still mode shifts color pixels for more vibrant color resolution
High-Precision Auto and Manual Focusing
Aperture-Priority AE and Program AE
3 Selectable image size settings:QXGA 2032 x 1536,XGA 1024 x 768, and VGA 640 x 480
3 ISO light sensitivity settings: 80, 160, 320
Manual exposure and white balance
Special effects Film copy mode*,Black and White*, Sepia*, and Negi-Posi (*applicable during playback)
Rugged metallic body, Easy access design buttons and controls
NTSC Video output, 1080i HDTV output
Video Player application (220KB) plays back video clips is provided
Video clips with audio too for e-mail friendly small size files (250KB for 20 seconds)
Exclusive high-speed interface printing via connector cable to optional GV-SP2 Digital System Printer which delivers 310 dpi color prints
BN-V37U Rechargeable battery pack
AC power adapter / battery charger
CD-ROM (USB Driver, Video Player for Windows 98/Macintosh)
Recghargeable Battery, AC Adapter/Battery Charger, 16MB SmartMedia Card, Film Copy Attachment, Hand Strap, USB Cable, CD-ROM, HDTV Output Cable, Video Cable
Approx. 290g (0.64 lbs) without a memory card or battery
NR Pro-Still (Noise Reduction) Mode (eliminates noise)
DR Pro-Still (Dynamic Range)
16 Megabyte SmartMedia removeable Memory card (optional floppy adapter available)
Speedy downloading via USB connectivity (Windows and Macintosh)
DCF File format and DPOF support
The GC-QX5HD is the newest, state-of-the-art, digital still camera from JVC. The 3.34 Mega Pixel CCD allows for high quality pictures at resolutions up to 2032 X 1536. The Manufacturer's suggested retail price is $1299.95
1080i HDTV Compatible Output, the GC-QX5HD can output a 1080 scanning line interlaced image- the same signal used by HDTV. Get ready for the "new rules" of television, with a high definition image and output that are ready for the task.
Pro-Still Technology offers several modes that improve picture even further when photographing stationary subjects.
The 6 Mega Pro-Still mode uses advanced pixel shifting to create an even higher resolution image equivalent to over 6 mega pixels. NR Pro-Still can be used to dramatically reduce picture noise by up to 9db.
The GC-QX5HD comes with a Film Copy Attachment that lets you shoot your old film negatives in 6Mega Pro-Still mode and make digital stills from them. This convenient feature makes digitizing your films quick and easy.
DR Pro-Still allows digital stills that approach the same wide latitude of conventional film by creating separate exposures for highlight & shadow areas. Then these separate exposures are combined. This, in effect, triples the cameras dynamic range.
The GC-QX5HD offers maximum creativity & convenience with collage modes, video e-mail capability, auto flash and a 200,000 pixel 2" TFT View Screen..
This JVC digital still camera is easy to connect via USB terminal, and both Windows & Apple drivers are provided. A special high speed connection is also offered for the matching JVC GV-SP2 printer.
Easy to use
The JVC GC-QX5HDu looks and feels much like a standard point-and-shoot film camera. The camera measures 4-3/8 inches by 2-11/16 inches by 2-3/8 inches and weighs 10 ounces with the battery. On the back, the camera has a large two-inch polysilicon TFT display that is a little dim but still quite legible. Included in the package are a lithium ion battery and a charger/AC adapter, so you can still use the camera while the battery is recharging. The battery is sufficient for around 50 pictures, which is good for a digital camera.
The JVC GC-QX5HDu is easy to use for basic photographs with the zoom conveniently located under your thumb. The mode selector is slightly recessed, so some may find it difficult to access. It's easy to forget about, which is a problem as many of the advanced features and playback options are reached via the mode selector. The power dial includes a lock button to deter accidental activation, but pressing the lock button and turning the dial simultaneously takes some getting used to. Changing settings is easy, with all the options showing up on a single menu. A directional button allows you to easily scroll through the menu and make the desired adjustments.
The camera includes an automatic shutoff when not in use. It's not a true sleep mode, since you'll have to turn the dial to off then back on to resume use. Though a great battery-saving idea, the camera should wake up when any buttons are pressed.
Four ports on one side of the camera allow you to output images to a TV or HDTV (1080i), an optional printer, or a computer. A DC input is also included in the port array. JVC includes a cover to protect the ports, but it isn't permanently attached to the camera and can be easily lost.
The camera has a 2.3x optical zoom lens (7.5 to 17.5mm; 35mm equivalent: 37 to 86mm). A 1/1.8th inch 3.34 megapixel CCD (3.24 megapixel effective) captures data and writes to a 16MB SmartMedia card. The camera has three standard resolutions of 2032x1536, 1024x768, and 640x480 plus three levels of JPEG compression. With maximum resolution and fine compression, you can take 16 pictures. At the lowest resolution and standard compression you'll capture 174 images. The camera also includes an uncompressed mode, storing images in TIF format, but you only get one picture at maximum resolution.
The camera's focus, metering, flash, shutter, and aperture can all be controlled manually. The camera also features some creative alternatives in Manual mode. Like many other cameras in its class, the JVC includes a Video mode capable of shooting 20 seconds of video with sound. JVC chose to use a proprietary format called JMM (160x120), so you'll need the player to view your videos. File sizes are small at around 300 KB, but the proprietary decoder makes it difficult to share clips and there's no way to convert them to standard formats. The player emulates the LCD on the camera and you can't view them full screen. For using a proprietary standard, JVC loses significant marks.
In manual mode, the camera provides 5 different settings. Three Pro-Still options (Noise Reduction, Pixel Shift, and Wide Range) improve the quality of stills by combining multiple images. Only Noise Reduction showed any noticeable difference and much of the true color was lost in the image. Collage Mode combines two separate images and Film Mode allows you to digitize pictures from your existing negatives. The JVC GC-QX5HDu includes an attachment that will hold your negatives and allow you to easily take pictures of them.
Image quality
Images are downloaded to a PC or Mac via USB. When taking scenic pictures outdoors we found pictures to be crisp with no artifacting; however images were darker than the true conditions. In macro mode images were crisp, but obvious noise was visible in the colors. Using the macro mode indoors, we found that images in the background were blurry and the images were darker than other cameras of similar quality. Compared to the Canon G1 and the Nikon 880, the JVC QX5HDu falls short.
The JVC GC-QX5HDu isn't as fast as the Canon G1, but it was quick compared to the Panasonic iPalm. In uncompressed mode, images can take over 30 seconds to process. In high-resolution JPEG format, the JVC processes images in around five seconds. It's not blazing fast, but within the acceptable range. With 'M. Drive' enabled, the camera will shoot three continuous images and you'll have to wait around 10 seconds for them to be stored.
PostPosted: Mon Oct 14, 2002 9:58 pm
Jack, are you coming to Vilseck next weekend?
PostPosted: Mon Oct 14, 2002 10:00 pm
I wish. I am still in Kosovo..
PostPosted: Mon Oct 14, 2002 10:04 pm
OK ... well, brakes are still working, so got time for that ... on the camera, sounds halfway decent, maybe we can talk once you get back?
PostPosted: Mon Oct 14, 2002 10:08 pm
Of course, but just don't try to talk me down. That price is firm :)
PostPosted: Tue Oct 15, 2002 7:05 am
OH yeah, and I also have a Compaq Presario PII 350mhz computer for sale. $250 or best offer.
PostPosted: Tue Oct 15, 2002 10:22 pm
Looks like the rotors/pads will fit, so put me down for them...
PostPosted: Tue Oct 15, 2002 10:50 pm
They're yours, and are you still thinking about the camera?
PostPosted: Wed Oct 16, 2002 7:34 am
Yup - when are you back (approx.)
PostPosted: Wed Oct 16, 2002 12:42 pm
Hopefully, I will be back around the 15th of November.
PostPosted: Sat Mar 19, 2005 2:03 pm
Guess what ;) Had the brakes done this morning ... nice to be able to brake without the steering wheel shaking like a wild bull ;)
