It is currently Tue Aug 25, 2026 3:56 am
 Post subject: Two Camaro chromed alu rims
PostPosted: Sun Dec 19, 2004 2:26 pm
OEM felgen- 16X8J
reifen- 96T P235/55R16 mit 50% profile
150 Euro nur an selbstabholer (you pickup)
minor defekt(leicht verkratzt)
PostPosted: Thu Apr 14, 2005 6:31 pm
100 euro
PostPosted: Mon Apr 18, 2005 11:20 am
Thinking about it... I could mount some semi slicks on them when running in Hockenheim... just for the 2 front tires...
PostPosted: Mon Apr 18, 2005 2:06 pm
Trying to get the backend to slip around on ya
PostPosted: Mon Apr 18, 2005 3:52 pm
Hm yeah that could happen, you're right. :D Was just thinking how to get more grip on the front...
PostPosted: Mon Apr 18, 2005 4:23 pm
Try Golbal west control arms and -1.5 to -2 degrees of camber
PostPosted: Tue Apr 19, 2005 11:10 am
It's not from Global West but you mean something like this, right:
http://www.lmperformance.com/825/1.html
PostPosted: Tue Apr 19, 2005 1:37 pm
Thats the adjustable lower control arm from LGM. Way over priced and redundant for the adjustability. Plus it does nothing camber curve or gain
I was referring the uppercontrol arm from Global west
PostPosted: Tue Apr 19, 2005 1:45 pm
i have
PA racing tubular lower a-arms chrome moly and
global west Tubular front upper control arm kit
in my camaro. Let´s see, how they work in Bitburg :wink:
PostPosted: Tue Apr 19, 2005 1:54 pm
Thanks Roy! :)
Jens, so what is your camber setting? I have roughly -1° (cannot quite achieve this on the right side) with stock a-arms.
PostPosted: Tue Apr 19, 2005 1:56 pm
Ben just extend the slot on the non conforming camber side.
PostPosted: Tue Apr 19, 2005 1:59 pm
I could do that... it's just that I maybe want to get even more negative camber than -1° on both sides. Now I could extend both slots/sides but I guess a more professional solution would be the upper a-arms...?
PostPosted: Tue Apr 19, 2005 2:06 pm
camber = -2°
i´ve checked it.
PostPosted: Tue Apr 19, 2005 3:07 pm
Jens could you shoot a picture of that lower A arm ??
The pics on their website are of poor quality and i wonder how rugged the shock platform is.
Why didn't you also go for the PA Racing uppers ?
PostPosted: Tue Apr 19, 2005 4:00 pm
http://fbodyeurope.org/phpBB2/viewtopic.php?t=5216
That will answer your question. :wink:
Are you in Bitburg in two weeks? I will be there, than you can look under my car. If not, i will make pictures from it
PostPosted: Tue Apr 19, 2005 5:15 pm
Ok, no problem .. Thanks
