It is currently Tue Aug 25, 2026 4:49 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Still got the LT1 for sale
PostPosted: Thu Aug 16, 2001 7:33 am
I still have the LT1 for sale if anyone is interested. It comes with the engine, wireing harness and computer. $1500.
PostPosted: Thu Aug 16, 2001 8:54 am
Would this fit in a 2nd gen? Would that make sense?
PostPosted: Thu Aug 16, 2001 10:50 am
Oh yea, it would bolt in! Just have to hook up the wireing and computer.
PostPosted: Thu Aug 16, 2001 11:29 am
Then you would really have a runner Garry!!
PostPosted: Thu Aug 16, 2001 5:26 pm
Randy, how old is it, how much has it run, and how many HP does it have at the flywheel? (still got to find a car first, though ... :))
PostPosted: Thu Aug 16, 2001 9:33 pm
The engine is from a 94 Z28 Camaro and has 95,000 miles on it. (I know) The engine is rated at 275 HP and 325 FTLBS of torque. It ran like a top before I pulled it out.
PostPosted: Sat Aug 25, 2001 10:13 am
how do think it would fit in a 1992 RS camaro?
the price sounds good. Give me some feed back.
need some more power and this might be the solution..
Hey, I like the name fbodyeurope.org!!!
PostPosted: Sat Aug 25, 2001 9:21 pm
I have the complete motor with all accesorys for sale. It will bolt on to your existing mounts. You will also need the wireing harness and computer, That also comes with the engine. Let me know what you want.
 Post subject: Hey Randy
PostPosted: Mon Aug 27, 2001 4:34 pm
I may need to buy a part off of you. I just did somthing stupid thinking I had another one and I didn't. I pried out the old opti gasket thinking I had another one and I don't. And I'm getting impatient with waiting for parts to come in. I talked to a German parts store and they said they could get one but i've been told those words to often to believe them. So if your willing to either trade out timing chain covers plus a few bucks for the hastle. Or I'll just buy the whole timing chain cover off of you. I'll trade out if you want to keep the Lt1 together.
PostPosted: Mon Aug 27, 2001 5:03 pm
Forget it.
The pre 95 opti spark units ARE NOT compatible with your 96 Z !!!
Not the unit, the cover, wiring, gaskets, etc .. nothing.
It would be a serious dissapointment to find this out after taking all that junk off :(
Sergio
 Post subject: not doubting what you said
PostPosted: Mon Aug 27, 2001 6:11 pm
Why would the timing chain cover be any different from a 93 to a 96? I thought that the only difference was the venting system on the opti spark itself. The only real reason I need the whole timing chain cover is for the opti gasket. I know it might be old but until I can get another one I'll just use that one. I just want to drive a few more times before I put it away for the winter or until it gets nasty out. This whole down for 2 1/2 months is starting to get to me.
PostPosted: Mon Aug 27, 2001 7:37 pm
Believe me, the cover is NOT the same !
There is a totally different hole in the cover and what not.
I'm doing a V6 to Lt-1 swap and i pretty much know ALL the engines and differences by heart as i made a study of it.
See it for yourself:
http://para.noid.org/~muttvette/opti.html
Sergio
 Post subject: You the man
PostPosted: Mon Aug 27, 2001 8:37 pm
Great info that was something I didn't know about the difference. Randy never mind I stand corrected.
PostPosted: Mon Aug 27, 2001 9:22 pm
Ryan call Jason at Pace Parts. They offer great prices and he will USPS Priority mail it ASAP..1 - 888 - 748 - 4655
 Post subject: thanks
PostPosted: Mon Aug 27, 2001 10:33 pm
I'll call them tommorow. I wish I would have just done the clutch and I could have been rolling by this weekend. You know how it is more more more!!!! It's addictive
 Post subject: Lt1 sounds good
PostPosted: Tue Aug 28, 2001 5:05 pm
sounds like the lt1 might be the answer I was looking for.
please e-mail. a little more about the lt1???!!!
PostPosted: Thu Aug 30, 2001 4:16 pm
Seen several 'oldtimers' and pickups running with Lt-1's in the states, BUT it did involve some serious work and mostly the Accel DFI setup to make it run good and save an enourmous amount of hassle to get it working properly.
Sergio
PostPosted: Fri Sep 14, 2001 7:00 am
Randy I have someone looking for a lt1 do you still have it?
PostPosted: Fri Sep 14, 2001 4:57 pm
I just sold it. If it fall's through (I dont think it will) Ill let you know.
PostPosted: Sat Sep 15, 2001 8:59 am
who got it?
