John,
Thanks!! Looks like I'll be going to 18X10s at all 4 corners with 285/35/ 18s. I jut need to figure out the proper offset with the new calipers and I'll be all set. Did yuou notice a difference in the handling or ride??
Retired US Army [img]http://www.fbodyeurope.org/gallery/110_Image098.jpg[/img
No problem Val. Yes I noticed a difference over my other set of wheels and tires 275's on 9.5 wheels. Feels a little more stiffer but a lot more stable in turns. W/ the camber settings it was a big improvement. When I switched to a 7/16 spacer up front vs the 5/16 it was a BIG improvement. So I'll be throwing the 5/16 w/ longer studs in the back this spring and see if it helps even more.
I've been meaning to ask you if you took any pics w/ the new brakes? I'd like to so them. Does stoptech make some for the rear as well?
Users browsing this forum: No registered users and 20 guests
