It is currently Mon Aug 24, 2026 7:55 pm
 Post subject: BMR Parts Arrive
PostPosted: Fri May 03, 2002 12:27 pm
I've got the bits (BMR CM STB, sway bar kit, box LCA's poly/rubber and relocation brackets, CM A PHR and tubular SFC's - all black).
Wow - they are heavy duty. The box LCA's are huge compared to the OEM. The front sway bar is really heavy. These components must help the car!!!!
QUESTION - does the front sway bar poly bushes use the OEM mounting brackets? I note the rear bushing kit has mounting brackets but the front only has the 32mm poly bushes. Please advise.
Still waiting for the springs and shocks. I will do all the mods at once to get the bigeest impact.
PostPosted: Sat May 04, 2002 4:36 pm
It uses the existing brackets.. :)
PostPosted: Tue May 07, 2002 12:29 pm
Thanks Jack
