It is currently Sun Aug 23, 2026 11:49 pm
 Post subject: Noisy sway bar
PostPosted: Wed Aug 06, 2003 5:38 pm
Hi,
I bought my car new on January 2000, and 2 months ago my rear sway bar began to make noise (it was the 1st time). :(
This noise comes from the big rubber bushings on the straight part of the bar.
I unmounted the 2 bushings and applied grease on the bar and on the bushings too. The problems is, I don't know if I've done the right thing, because 1 month later, these f****g bushings make noise again :x :x :x
Can someone tell me what to do ? (Except a poly kit because a friend of mine had one on his 81 vette, and it was VERY noisy too).
Many thanks,
Fred
99 V6 Camaro coupe
Bright Silver Metallic
Free Ram Air mod
The more you mod it, the less you drive it...
PostPosted: Wed Aug 06, 2003 6:11 pm
on my '98, I didn't have the problem - but the suspension is a major PITA ... you may want to think about getting the BMR swaybars, great improvement - not sure but I think they come with a set of poly bushings...
PostPosted: Wed Aug 06, 2003 6:30 pm
You could drill and tap the mount so you can add a grease fitting. Make sure that you are using a good moly grease. You don't want something that will "melt" away. You could also try some anti-seize if you have a lot of dirt getting in the grease. The anti-seize doesn't attract dirt as much.
Or, you could get a 572 cubic inch big block from Bill Mitchell. Now you won't hear any more noise coming from your swaybars! :wink:
PostPosted: Tue Aug 12, 2003 7:51 am
The BMR bars do come with poly mounts - both mid and end but try their silicone grease which is what you're supposed to use on these bushings.
http://www.bmrfabrication.com/misc.HTM
