It is currently Mon Aug 24, 2026 12:13 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: front sway bar by strano performance
PostPosted: Sat Jun 12, 2004 9:09 pm
Does anyone know about:
We do offer a 35 MM Hollow sway bar made for us by Addco. It weigh 14
pounds less than the ST bar and works every bit as well.
Is there any Pro/Cons compared to the BMR solid 32mm sway bar?
thx
Roozbeh
PostPosted: Sat Jun 12, 2004 9:11 pm
With a 3400 pound car, what's the point in saving 14 opposed to the pros of a stiffer SB?
PostPosted: Sat Jun 12, 2004 9:18 pm
This was his suggestion to me because of shipping costs being too much for the ST-bar. I was actually wondering if this bar is stiffer than the BMR solid 32mm bar.
thx
PostPosted: Sat Jun 12, 2004 9:30 pm
I wouldn't think so ... I don't know this sway bar, but I have the BMRs on mine ... but then, anything is better than the stock sway bar ... :)
PostPosted: Sat Jun 12, 2004 9:33 pm
Thanks Garry then I will go with the bmr bar either :)
PostPosted: Sun Jun 13, 2004 7:53 am
Nice car LS1, and you really don't need a 35mm sway bar. 32mm is more than enough. It is a very strong piece, but it's up to you!
PostPosted: Sun Jun 13, 2004 8:18 am
Well, actually I wonder whether the 35mm hollow would be as strong as the 32mm solid ...
PostPosted: Mon Jun 14, 2004 11:00 am
Let me quote Sam Strano:
"The stiffness is less, but not hugely so [compared to a solid 35mm bar]. For instance there are less bends in the hollow bar that help gain back some stiffness. It is softer, but nowhere near as soft as solid 32's are."
LS1:
BTW, I have the 35mm ST and the 21mm 1LE bars and I'm very happy with them on the track.
PostPosted: Mon Jun 14, 2004 5:13 pm
Ben thanks for your information. As I have an automatic trans do you think it would be a big difference to buy a torque arm in order to get more traction?
PostPosted: Mon Jun 14, 2004 5:55 pm
Oh... can't answer that... maybe someone else...?
PostPosted: Tue Jun 15, 2004 4:32 am
Torque conter won't help you gain traction .
PostPosted: Tue Jun 15, 2004 12:54 pm
DAmn I love the stance of your car in that pic Ben! ;)
PostPosted: Tue Jun 15, 2004 1:56 pm
@Roy:
Thanks, but I was talking about Torque Arm and not Torque Converter.
So if you think Torque Arm won't help me gain more traction what can I do to get more traction, with the exeption of other tires? I already have aftermarket LCA's, Panhard rod and Bilstein HD shock absorbers. Thank you.
Roozbeh
PostPosted: Tue Jun 15, 2004 3:03 pm
A torque arm will help you with traction. If you have the cash, buy the TracLink system. I think it's about $500. That is really all you can do to increase traction, unless you're drag racing. Then you could get a set of slicks and definitely have traction.
PostPosted: Tue Jun 15, 2004 3:42 pm
yes a torqu arm will help, Iwould stay away from the GW trac link, its a little tricky to setup , The LG torqu arm is just as good plus it won't ben your floorboards. But it is all for nothing if you don't have a decent set of street tires.
PostPosted: Tue Jun 15, 2004 3:49 pm
Me too! This is by far the best Nuerburgring picture of my car! :D
PostPosted: Tue Jun 15, 2004 4:06 pm
ben is that headed up to the Flugplatz
PostPosted: Tue Jun 15, 2004 4:34 pm
No it's Breidscheid, up to Ex-Muehle.
PostPosted: Tue Jun 15, 2004 7:33 pm
@Roy:
What brand would be a decent set of street tires? I have the
P245/50 ZR 16 Eagle GS-C's. Do you think the Kumho's are a better choice for traction? thx
PS. What about the cheaper ($160 non adjustable) Edelbrock torque arm ?
My car is not lowered, do I need to adjust the pinion angle anyway or can I go with the non adjustable torque arm?
PostPosted: Tue Jun 15, 2004 10:06 pm
:shock: Yep, you need new tires. I have the Kumho's. They are OK after you heat them up and only when new. The good thing about them is that now I can chirp the tires going in 3rd at 75mph. :twisted: Wait a minute, that's not good unless showing off. :oops: Personally, I loved the BFG Comps when I had them. The Firestone SZ50s give up some dry traction for wet like the Kumhos, but the SZ50s had more traction. The only Goodyear's that I would get would be the F1s and they're not cheap. How about the new Bridgestones?
Users browsing this forum: No registered users and 31 guests
