It is currently Mon Aug 24, 2026 4:27 pm
 Post subject: Panhard bar questions
PostPosted: Wed Nov 03, 2004 4:32 pm
This goes to everyone with a different-than-stock panhard bar:
Which one did you get & why (besides the ability to re-center the rear axle)?
What difference does it make on the street and on the track?
What combination is the best: poly/poly, poly/rod or rod/rod?
Thanks! :)
PostPosted: Wed Nov 03, 2004 5:37 pm
BMRpoly/poly adj bar/ The price was right
Normal Street driving not a thing. On road courses in compression (right hand turns) the stocker will bow to the point of bending.
Poly rod would be the best
PostPosted: Wed Nov 03, 2004 8:25 pm
yeah, what Roy said, except I have the Granatelli! ;)
PostPosted: Thu Nov 04, 2004 10:17 am
OK, question is: What's the problem with that?
PostPosted: Thu Nov 04, 2004 12:05 pm
I don't understand your question Ben.
PostPosted: Thu Nov 04, 2004 1:03 pm
I am not for sure but I think he might be asking what adverse effects would come from having a bent panhard bar. exe. rear end not being centered or alligned. maybe?????
PostPosted: Thu Nov 04, 2004 1:29 pm
No, when the stock "panhard rod" bends, it makes the rear slightly less stable or firm than it would be with a solid, or non-bowing phr.
PostPosted: Thu Nov 04, 2004 1:43 pm
Yes, that's what I wanted to know, thanks. :)
So basically it helps with the stability while going around a corner...
PostPosted: Thu Nov 04, 2004 1:55 pm
my answere was kind of a question.
PostPosted: Thu Nov 04, 2004 3:07 pm
Yes, precisely.
