It is currently Mon Aug 24, 2026 4:07 am
 Post subject: Wheel alignment
PostPosted: Wed Apr 20, 2005 12:59 pm
Well, since I've done all this stuff now, I need to get my wheels aligned. Anybody have some good aggressice street specs I can give them. Kinda don't want to just go back to stock.
Know what I'm sayin?
PostPosted: Wed Apr 20, 2005 2:01 pm
Camber -1
Caster +4,5
Toe 0,0
is what I have. Can't hurt to try to get a bit more negative camber (-1 is max negative what I can get) when you're running on the track from time to time...
PostPosted: Wed Apr 20, 2005 3:54 pm
BenZ28 wrote:
Camber -1
Caster +4,5
Toe 0,0
Go with what Ben Said for starters.
PostPosted: Wed Apr 20, 2005 5:06 pm
Careful with too much negative camber up front. Apart from the problems of tire wear and that the car becomes very nervous in a straight line (how do I know that!), you increase the front end traction, which means that the tail will come around quicker. No problem if you are a good driver, but not so good if you are dozing along.
PostPosted: Wed Apr 20, 2005 5:41 pm
Yes it does get a little twitchy and tram in the ruts in the trucklane
PostPosted: Thu Apr 21, 2005 12:07 pm
...it already does with my current settings. How much camber do you have, Roy?
PostPosted: Thu Apr 21, 2005 1:22 pm
-2deg, But my tires are cheap any ways so I don't mind going through 3 or 4 sets a year.
