It is currently Mon Aug 24, 2026 5:31 am
 Post subject: LCA Relocation Brackets-Affect on Handling
PostPosted: Fri Aug 31, 2007 5:08 am
I just installed some relocation brackets to cure bad wheel hop. I know it will adversely affect handling some, but how much should I expect? Will it scare the crap out of me, or just be a little worse? Just don't want any major surprises.
PostPosted: Fri Aug 31, 2007 5:37 am
You probably willnot even notice the difference unless you are really pushing it through a slalom. Lowering the rear portion of the lower axle control arm will increase roll oversteer . This can be a good or bad thing depending on how much oversteer it is.
