It is currently Tue Sep 29, 2026 7:27 am
 Post subject: K&N FIPK II
PostPosted: Sun May 09, 2004 1:18 pm
This week I installed the K&N FIPK II to my Z28. As some of you know, I was screwed in buying the kit via internet, the heatshield wasn´t in the parcel.
I had to leave the lower part of the stock airbox, because it holds the radiator and the cooler in position.
Thanks again to LuS1fer, who send me the little filter I needed too and wich is installed on the right side.
If it works well, I will see at Bitburg ;) :D
But I think, I fellt the gains, the car is running better :D :D :D
http://www.martinerne.de
PostPosted: Thu May 13, 2004 4:09 pm
That actually doesn't look too bad. Nice work! ;)
PostPosted: Fri May 14, 2004 8:49 am
It probably works better than K&N's version. You've got a direct cold feed underneath and a shroud around it to stop it sucking so much engine heat. All you have to do is find some of that rubber trim to finish off the edges.
