It is currently Mon Aug 24, 2026 9:59 am
 Post subject: Good cheap oil cooler. Roy or Val?
PostPosted: Thu Jan 04, 2007 9:52 am
I remember you guys a couple of years ago buying and installing them at the same time. Where did you get it from and for how much? Anything under a 100 bucks seem reasonable? I've looked all through Summit but couldn't find nothing small like yours. I've seen pics of Vals as I still have them on my HD.
Will a tranny cooler do just the same? Seems those are a lot smaller but then again I do need something that'll support 800rwhp.
Thanks!
PostPosted: Thu Jan 04, 2007 10:16 am
John where are you gonna stick it ?
Your best bet is water to air oil cooler that is plumbed into your lower radiator hose. MOCAL COOLERS
laminar flow cooler
PostPosted: Thu Jan 04, 2007 12:23 pm
I was actually going to place it in front of the radiator since I removed my AC support core etc. Since I'm running 2 puller fans plus the air dam I figured that would be enough air going through?
Thanks for the link Roy.
PostPosted: Thu Jan 04, 2007 12:28 pm
Roy are those air to air?
PostPosted: Thu Jan 04, 2007 3:52 pm
The MOCAL's are air to oil
The L-cooler is water to oil
PostPosted: Thu Jan 04, 2007 4:00 pm
Ok. Which one are you using? What's you opinion of this one here? It's a B&M unit for 70 bucks.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70266&N=700+%2D128262+115&autoview=sku
PostPosted: Thu Jan 04, 2007 4:17 pm
I am using a MOCAL unit.
I have no experience with the B&M model. But it looks to be of the same design.
Users browsing this forum: No registered users and 12 guests
