It is currently Mon Aug 24, 2026 9:28 am
 Post subject: MAF Bypass in stainless steel or aluminum
PostPosted: Mon Feb 04, 2008 6:05 pm
I need a piece of thinwall in the dimensions that are on the attachment. The 90 mm diameter is the outside diameter not the inside. Could possibly do 91 mm. Inside diameter can't be no less then 87/88mm
 Post subject: Re: MAF Bypass in stainless steel or aluminum
PostPosted: Mon Feb 04, 2008 10:18 pm
Roy call Matt at 01726292226 he should have what you need laying around in a trash bin. I am sure he can polish it for you if needed. All he does is SS fabrication.
PostPosted: Tue Feb 05, 2008 5:40 am
Sounds like a piece of exhaust tubing would do ... so just about any truck place should be able to supply you with it ...
PostPosted: Tue Feb 05, 2008 11:54 am
James I will give him a call
Garry if it was only that simple. 90 mm pipe and the Pitstop dumbfounded.
PostPosted: Tue Feb 05, 2008 12:06 pm
If it was 3" I've got that laying around all day. :(
PostPosted: Tue Feb 05, 2008 12:48 pm
PitStop isn't a truck place ... German cars do NOT use exhaust pipes that size ... heck, we have more CUI in one cylinder than some cars got in total ...
PostPosted: Tue Feb 12, 2008 8:39 pm
I showed Matt the post here and he said he really needs to talk to you about it. Matt is really into metal work and really knows his stuff. Must be his Meisterzertificate and his tinkering he does.
PostPosted: Wed Feb 13, 2008 11:58 am
Hey James I found a piece that will work. Just have to get it cut to 95mm now.
PostPosted: Wed Feb 13, 2008 8:15 pm
Call Matt, :lol:
