It is currently Sun Aug 23, 2026 10:49 pm
 Post subject: AAAAARRRR Fing start
PostPosted: Sun Aug 15, 2010 5:24 pm
hi guys
as you can prob tell getting a little fed up of my ta at the mo
got her about 5 mouths ago knowing she needed work and was going to be a summer project. main problems bad wiring and the floor is gone.
any how been working on her all the wiring is done now.
last week did a trans fluid/filter change.
flushed the rad out
took of the pulley for the supercharger as it was buckled sorted it and put back together
and now she just wont start
has spark, fuel and air but will not catch
she tyring but just not good enough
please any ideas guys would be great
o and she a 3rd gen 5.7 tpi
 Post subject: Re: AAAAARRRR Fing start
PostPosted: Sun Aug 15, 2010 6:02 pm
tps, iac, bad computer, ignition module went out, dist. is 180 out.. could be many things. what wiring issues?
PostPosted: Sun Aug 15, 2010 6:37 pm
the wires was just a mess from who ever did the blower just been sorting them out
PostPosted: Sun Aug 15, 2010 7:16 pm
I would check the mechanicals first. then check the electronics.
PostPosted: Mon Aug 16, 2010 7:01 pm
had another go today still the same
PostPosted: Wed Aug 18, 2010 8:22 pm
she works at lasted bloody thing
ended out to be wet plugs whipped out 5 that i could get to and they were covered in fuel dried them of put them back in and of she went
thanks for your help guys
[youtube]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/oZ4sro3kUNo?fs=1&amp;hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oZ4sro3kUNo?fs=1&amp;hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/youtube]
PostPosted: Thu Aug 19, 2010 7:06 am
Glad you figured it out . Sometimes the most simple stuff just gets in thee way. Fixed your link
PostPosted: Fri Aug 20, 2010 7:57 pm
thanks dude
you tube has been very funny at the mo
