It is currently Mon Aug 24, 2026 5:48 pm
 Post subject: Aaargh! It´s making me crazy!!!
PostPosted: Sat Apr 26, 2003 10:15 am
I poured almost a full 6 qurts of engine oil in and the oil measure thingy still says ad!!! Regardless if warm or cold. Although the Low Oil light is off.
What now?
Frustrated :(
Got boost?
PostPosted: Sat Apr 26, 2003 10:26 am
Put the filter back on :lol:
PostPosted: Sat Apr 26, 2003 11:32 am
You add oil, but your dipstick doesn't show a higher level?!
My dipstick shows a wrong level when it's inserted in the wrong direction (when the "XXX"s point to the rear, i think, but this could be V6 specific), because when i pull it out some oil is wiped away.
You measured on flat ground and the dip stick was fully inserted? (just to be sure :wink: )
 Post subject: Hmm...
PostPosted: Sat Apr 26, 2003 1:03 pm
Guess i´ll re-check it now.
Gosh, i hate it when that happens.
Da R@M
Got boost?
PostPosted: Sat Apr 26, 2003 2:25 pm
lol, as far as I know it only hold 5.5 qts. Although, when I was in Virginia, I caught the dealer trying to charge me for 7 qts on two occasions. When confronted, he said must have been a typo. I bet they do it to poeple all the time, pissed me off cause we all know, synthetic oil ain't cheap :x
PostPosted: Sat Apr 26, 2003 5:39 pm
That's why I change my own oil. It's just too easy!
PostPosted: Sun Apr 27, 2003 6:28 am
Hm ... you make me think - need to go and check my last bill, too ...
PostPosted: Sun Apr 27, 2003 3:28 pm
:twisted: I did it myself... :twisted:
Shows a little over add now.
Darn
Got boost?
PostPosted: Tue Apr 29, 2003 8:41 am
I should log in before posting. :?
So, what was wrong?
PostPosted: Tue Apr 29, 2003 4:05 pm
Make sure you're dealing with US quarts and not imperial quarts.
Oil have to go now. Mine doesn't use any oil - annoying eh? :shock:
PostPosted: Thu May 01, 2003 6:36 pm
no oil?
I need lots of oil, at least one quart synthetics every week...
:shock:
