It is currently Mon Aug 24, 2026 8:15 am
 Post subject: another rear end swap question
PostPosted: Fri Jul 08, 2005 12:19 pm
i have a 82 Z28E and a 94 limited slip axle. is there a way to swap this axle on my 82 ?
is this a bolt on swap ? just want to burn both rear tyres, no strip planned !!
thanks for your help
Lilian
PostPosted: Fri Jul 08, 2005 12:21 pm
as far as I know it will work your rear wheels will stick out alittle further though
PostPosted: Fri Jul 08, 2005 1:42 pm
Yes it will bolt up . Wheels will stick out slighty more. You will have to fab some lines and think about the E-brake setup.
PostPosted: Fri Jul 08, 2005 5:55 pm
thanks guys
the axle is complete so will retain with rear disc brakes. i will take some measurements on the width because I already have 235*60*15 tyres.
thanks again
