It is currently Sun Oct 25, 2026 11:35 pm
 Post subject: Shifting problem
PostPosted: Fri Aug 19, 2005 4:53 pm
I ordered a new 2nd servo for my 92 camaro from summit. I put it in and it was not shifting into 2nd. I pulled it back out called them and they said it wasn't machined right etc. So I put the stock one back in and now it shifts into second then when it shifts to third it islike I am putting it in nuetral, the engine revs up but I ain't going no where. Anyone got any ideas of what this could be? Any suggestions would be appreciated. Yes there is enough fluid in it.
Ditch the *itch, lets go racin'!!
PostPosted: Fri Aug 19, 2005 7:45 pm
Did you do any air pressure checks ?
PostPosted: Sun Aug 21, 2005 8:34 pm
what do you mean by air pressure checks?
PostPosted: Sun Aug 21, 2005 11:29 pm
not for sure if this is what he means but I would guess he meant to check the fluid pressures. but I could be wrong
PostPosted: Mon Aug 22, 2005 8:51 am
Probably looking for and internal leak. Make sure you put the springs back in correctly.
