It is currently Mon Aug 24, 2026 4:24 pm
 Post subject: Diff question
PostPosted: Wed Apr 19, 2006 5:09 pm
I've got a question for those who know a bit about differentials in our cars:
Let's say I'm parking with the 2 passenger-side wheels in the mud or on a slippery surface, and with the other 2 wheels on dry asphalt. How come I'm spinning the right/passenger rear tire and cannot get the car to move a bit although I've got a locking-type (stock) diff in my car?
PostPosted: Wed Apr 19, 2006 5:53 pm
Ben You have either exceeded the maximum torque that the Limited slip can transfer to the non slipping wheel or the clutches are totally shot.
If its a Torsen it needs some traction to transfer torque to the non slippping , non spinning wheel. If you have traction control , the lowspeed setting will actuate the rear brakes to stop the slipping wheel from spinning , which will transfer torque to non spinning wheel. But if your already stuck its not gonna help.
PostPosted: Thu Apr 20, 2006 8:52 am
Thanks for the explanation, Roy. Yes I have a Torsen without clutches.
