It is currently Mon Aug 24, 2026 8:25 pm
 Post subject: Winter Mods
PostPosted: Mon Dec 18, 2006 6:05 pm
Like the topic says, what are you all planning as far as upgrades this winter? Mine is currently on the way home. If I don't go play in the sand again I plan on a few upgrades.
1. Magic Stick 4 Cam from Texas Speed
2. Fully ported Trick Flow Heads
3. Ford 9" rearend
4. Chromoly K-Member with upper and lower control arms
5. 10 point roll cage
6. TH400 tranny with transbrake
7. Second stage of nitrous with a plate kit
8. Send the Fast 90mm intake off to get ported
That is about it. I want this car to run mid to low 9's on a good track. More safety upgrades will come as the car progresses towards my goals.
PostPosted: Mon Dec 18, 2006 6:14 pm
383ci stroker w/11.8-1 cr
Custom grind cam from Lloyd Elloit
Ported Trick Flow heads from Lloyd Elliot
The Viper internal T-56
Strange Dana 60 w/3.73's
Tires for my Weld Drag lites
NX Nozzle kit for 180hp shot
And a 10 sec time slip!
PostPosted: Mon Dec 18, 2006 6:39 pm
402 SDPC Alloy block -14cc diamond pistons.
Fast90 intake
NW 90 mm throttlebody
LS7 clutch kit
Will swap my dart 205's onto it and dump my LS6 intake and TB.
Hoping for around 450+rwhp and similar torque.
PostPosted: Mon Dec 18, 2006 7:24 pm
Hmmm....
-Get after 7 months finally a german registration for the convertible :x
(= bolt in those four H4 headlamps, wire up the rear fog light, put
2 extra fuse boxes into the rear lights, remove the annoying SES light
caused by the 3" cat... and find a TÜV guy who accepts that a firebird convertible is 99% the same car as a camaro convertible...)
-Pull the engine & trans from the yellow one and check what fits in there
-Bolt a throttle body, air cleaner and exhaust on the 90% finished GTZ and fire it up finally...
PostPosted: Tue Dec 19, 2006 4:56 am
G-Force tranny and a 9"........possibly a cage but we'll see. Oh and a hill........something for me to push the car to get moving. Don't need any of it right now but I'd like to have a backup. :twisted:
PostPosted: Tue Dec 19, 2006 6:18 am
Tires and more tires
PostPosted: Tue Dec 19, 2006 1:15 pm
Brake pads and rotors. :lol:
PostPosted: Tue Dec 19, 2006 2:32 pm
Dito on the brakes ... and some other small parts ...
