It is currently Tue Aug 25, 2026 2:15 am
 Post subject: Tire pressure?
PostPosted: Sun May 13, 2007 7:48 pm
Just wondering ... when putting on the new tires, I checked the pressure ... the BFG's have 44PSI (~3bar) on the side wall ... the old ones (that I put in front) don't have anything written on them ...
What do other people run in their tires? (275/40/ZR17)
PostPosted: Sun May 13, 2007 9:24 pm
34 psi for all 4 tires. 44 psi is the max pressure.
PostPosted: Sun May 13, 2007 9:28 pm
yeah, that's what I meant ... I usually run at 2.3-2.4bar in the tires ...
PostPosted: Mon May 14, 2007 10:37 am
What you saw is that maximum pressure. I run my tires with about 2.4 bar front and rear. BTW what tires did you get?
PostPosted: Mon May 14, 2007 10:52 am
BFG ... ratings I found on the net seemed pretty decent ... guess I'll know more after next weekend ;)
PostPosted: Mon May 14, 2007 4:11 pm
I've always run 30psi on my Hawk and I've never had uneven tire wear. I'd like to know what you think about those tires too.
PostPosted: Mon May 14, 2007 5:13 pm
Which BFGs (wasn't that also an abbreviation in Doom or Quake?)? KD, KDW, KDWS, ...? :)
PostPosted: Mon May 14, 2007 5:15 pm
g-Force Sport ...
PostPosted: Fri May 18, 2007 5:14 pm
Running 2.4 bar in my 275/40 17 tires. BTW, these tires have really good dry traction. Wet traction is also pretty good, Michelin Pilot Sports.
