It is currently Mon Aug 24, 2026 8:15 am
 Post subject: Just getting a conversation going here....What would cause..
PostPosted: Sun Dec 02, 2007 9:14 pm
I came upon this problem today with someone I was helping. What would cause 1 pad on a disk brake to wear EXTREMELY quickly? It was the outside pad away from the piston.
PostPosted: Mon Dec 03, 2007 7:11 am
Well if its a floating caliper my money would be on sticky caliper guide pins.
PostPosted: Tue Dec 04, 2007 7:29 pm
that or the piston is frozen
PostPosted: Tue Dec 04, 2007 10:20 pm
That was my initial thought, but wouldn't that cause both pads to wear?
PostPosted: Wed Dec 05, 2007 6:03 pm
Just look at the construction of the caliper and you will see.
Heck take it apart and clean the guide pins and regrease with hi temp anti seize
PostPosted: Wed Dec 05, 2007 6:56 pm
on a floating caliper it would
 Post subject: Re: Just getting a conversation going here....What would cause..
PostPosted: Wed Feb 13, 2008 11:30 pm
Brain its your pads giude rails * were the ends of the pad sit in the calpier houseing*....we just went over this in clas tonight. If the piston stuck then both pads would be FUBAR but if one sticks its not slideing back after the compression is off..mines doing simular crap right now.
