It is currently Mon Aug 24, 2026 8:14 am
 Post subject: Sealed front wheel hubs for 4th GEN camaros
PostPosted: Fri Dec 28, 2007 7:59 pm
Okay After my second set of factory hubs went out in in less than ten thousand miles , I decided to buy the Timken sets because there half the price then GM .
Guss what,the hubs are one and the same, right down to the casting numbers so save yourself some money and get the cheaper TIMKEN SET.
 Post subject: Re: Sealed front wheel hubs for 4th GEN camaros
PostPosted: Fri Dec 28, 2007 10:06 pm
Do we use the same hubs?
Sounds familiar - OEM Corvette: ~$300 from GM - Timken: ~$150 from Autozone. Couldn't find a single difference other than the box it came in and I've never seen or heard of a cardboard box being worth $150
PostPosted: Fri Dec 28, 2007 10:19 pm
Keith Our hubs bearing bolt pattern is different.
I payed 250 apiece from Pace performance for Originals and 150 apiece from Autozone for Timkins. The hubs are exactly the same right down to the numbers on the spindles. Go figure!
