It is currently Mon Aug 24, 2026 2:54 am
 Post subject: rear end gears?
PostPosted: Wed Feb 13, 2008 8:20 pm
I was wondering if I should put different ratio gears in my rear end ... stock is 3.42, 4.10 would hurt top speed & economy quite a bit, so 3.73 might be a good compromise ...
Any comments?
 Post subject: Re: rear end gears?
PostPosted: Wed Feb 13, 2008 11:25 pm
garry on a M6 all that I have ever read leads me to believe that 3:73's are a great choice
So far I would take back my stock 3:23's in my A4... Im hurting all through the RPM band and driveablity sucks...then again it could be caus emy tranny is acting up
PostPosted: Sun Apr 20, 2008 10:22 pm
I got 4.11's in my 89 with a M29 T56 and I can cruise at a 100mph at 2500 RPM. It's still good around town also the only thing that is no good is I still have the TPI so I go through my power band pretty fast lol.
1989 IROC Z28 350 TPI, T56 out of 95Z, 98 TA rear 4.11's.
PostPosted: Mon Apr 21, 2008 2:36 pm
I have 3.50's in my '88 with a 6 speed, it accelerates pretty quick and I still get good fuel economy out of it. I wouldn't go above 3.73's, but I keep hearing about gear "whine" with that ratio.
PostPosted: Thu Apr 24, 2008 12:49 am
4.56's will give you a kick......yeah, you'll lose gas mileage, but with mine I can still bury the 150 speedo!
It really is a balancing act and will depend on what you want. I had 3.23's in my 93 6spd. Truthfully, I didn't notice any increase in gas mileage, but I am dam sure it would hit between 180-190 MPH on the bahn.
I would recommend either a 3.73 or 4.10. Since you are buying gas on the local economy I would lean toward the 3.73's
PostPosted: Thu Apr 24, 2008 4:02 pm
3.73's in mine and quiet as all get out. She wraps up too quickly for me now and feels like Brian's 4.56's. :D 3.55's will go in when I get back stateside in 2 mos.
The "SRZ"
