It is currently Wed Oct 21, 2026 2:49 pm
 Post subject: change breake fluid in 98 camaro! Best brand and how many ?
PostPosted: Sun Feb 24, 2008 1:57 pm
I will change all my fluids in my 98 Camaro 3.8 with automatic!
I need the info, how many brake fluid must i order to change all incl. the lines? Which is the best for me?
Is this possible and a good upgrade to change to DOT4 or DOT5 or DOT5.1 ?
Thanks
 Post subject: Re: change breake fluid in 98 camaro! Best brand and how many ?
PostPosted: Sun Feb 24, 2008 4:53 pm
Ate Super blue. You can pick it up at Trost special order. Takes 24 hours or some of the other auto teile markts.
It is a superior Dot 4 fluid. One liter is plenty .
PostPosted: Sun Feb 24, 2008 8:30 pm
You do not need DOT 5, it's a race fluid that will cost you 3-4 times more. It's also silicone and is not compatible with regular brake fluid, you'd have to flush your system before installing it.
PostPosted: Sun Feb 24, 2008 11:59 pm
Thanks
if you want to get crazy Castrol SRF is pretty much the best stuff made @ $70+ a bottle and good luck finding it. ATE Superblue is good stuff and easy to get. You can also get ATE Type 200 which as the exact same specs and Superblue, just normal colored so when you change the fluid if you swap back and forth between them, you can see when all the old fluid is out or make a nice green colored fluid if you mix it right :lol:
DOT 3 and DOT 4 are compatible. Change DOT 3 every 2 years and DOT 4 every year.
