 Post subject: Engine not firing LS2
PostPosted: Fri Mar 07, 2008 6:53 pm
Hey guys
I swapped a LS2 from a 05 GTO in my RX7 and have now completed the work. The problem is the engine just wont fire up. It will crank happily but I get no fuel and no spark. My wiring is done right I checked it many times and I get the switched constant 12V to the coils and the injectors its the pulsed signal that is totally lacking. I have Aeroforcetech OBD2 gauges hooked up to the OBD2 port and they show my all the engine stats. I get an RPM signal on cranking and it does some stuff with the fuel tables as I see it. The gauges also have a option to show DTCs but no faults show up.
Fuel Pump gets turned on an primered by the ECU and the fuel pressure is right at 58PSI.
Does anybody have an idea what it could be? I double checked on everything. Engine and is PCM are perfectly grounded. The switched and constant 12V sources are clean and all fused.
 Post subject: Re: Engine not firing LS2
PostPosted: Fri Mar 07, 2008 9:30 pm
Sounds like VATS is interfering.
PostPosted: Fri Apr 25, 2008 9:48 am
( Very Annoing Throttle Sensor) VATS ?
PostPosted: Fri Apr 25, 2008 10:35 am
I don't think it is VATS if the fuel pump is priming. I will have to look at my manual to confirm though.
PostPosted: Tue Apr 29, 2008 11:19 am
Hey all -
It was VATS... he got it cleared with HP Tuners and is running... but now waiting on the car back from the paint shop.
PostPosted: Tue May 06, 2008 7:36 pm
anyone care to enlighten me what VATS actually stand for :?:
PostPosted: Tue May 06, 2008 8:25 pm
Vehicle Anti Theft System
If the key resistance is not recognized by the VATS module, the starter and fuel pump are disabled for 10 minutes.
PostPosted: Tue May 06, 2008 8:26 pm
How did HP Tuners clear a VATS problem though? Usually you have to clean the cylinder contacts to correct it.
PostPosted: Wed May 07, 2008 6:47 am
I guess what he meant is the VATS was disabled in the PCM ... in EFILive it's G1201 and G0801 ...
PostPosted: Wed May 07, 2008 9:26 am
Ahhh.
