It is currently Mon Oct 19, 2026 9:32 pm
 Post subject: clutch release bearing question
PostPosted: Mon Sep 28, 2009 8:51 pm
it's a long shot, but you never know...
Does anybody perhaps have an old NON HYDRAULIC clutch release bearing from a gm car ?
i need a shorter one then the one i have
And i need an example so i know what to order new...
left is the one i have and all dimensions are perfect except the height.
when looking at it, there must be some chevy bearings that are shorter ..
the one one the left is from some old chevy truck (mucie?) setup apparently
i cant use the one on the right as this one is from bmw and has a too small diameter bearing fot the pressureplate..
 Post subject: Re: clutch release bearing question
PostPosted: Mon Sep 28, 2009 9:23 pm
The camaro 82-92 clutchbearing might be the one i need, i would just need the dimensions from this one....
PostPosted: Tue Sep 29, 2009 5:06 am
Sorry
None here
