 Post subject: Why does the inspection process have to suck?
PostPosted: Wed Nov 04, 2009 7:38 pm
They said my bald tires were good, my leaking diff was no problem, and my howling parking brake was good. My tie rod ends? FAIL!! They sounded like fire crackers on the tester. I'm glad they caught them before they got really bad, but there goes another 150 euros down the tube. Oh well. That's what happens with 90K+ miles.
And thanks again Billy for letting me borrow the tires, even though I didn't end up needing them. It's nice to see that this community can help each other out.
Jeremy
Bitburg, Germany
2002 WS6, SLP lid
"Trans Ams are like beligerent, unrefined Corvettes."
 Post subject: Re: Why does the inspection process have to suck?
PostPosted: Wed Nov 04, 2009 8:12 pm
You never know what to expect from inspection.
150E is pricey for some tie rod ends. Does that include install and alignment?
PostPosted: Thu Nov 05, 2009 1:46 pm
150 includes the parts and labor, plus the allignment, so it's not too bad. I could've waited for the parts to come from the states, but I'm impatient. Mark Lebida in Binsfeld is getting the parts overnight, and should be fixed on Monday.
Jeremy
Bitburg, Germany
2002 WS6, SLP lid
PostPosted: Thu Nov 05, 2009 5:56 pm
No problem Jeremy...anytime.
01 TA-M6-Blue
PostPosted: Thu Nov 05, 2009 6:24 pm
Yeah, that isn't bad then. gl with the inspection again.
PostPosted: Fri Nov 06, 2009 5:59 pm
Well, I should be alright this time since that's all they can look at. It will be done Monday, so fingers crossed!
Jeremy
Bitburg, Germany
2002 WS6, SLP lid
PostPosted: Fri Nov 06, 2009 9:26 pm
Like Brian said, good luck. They hit me up for a DB test this year... It pulled something around a 96 or so. I don't know if that's good/bad or what the reg says.
01 TA-M6-Blue
PostPosted: Fri Nov 06, 2009 10:57 pm
Am I right in thinking that if you get reinspected within 30 days of the first one, they can only look at what they failed you for and not anything else?
Jeremy
Bitburg, Germany
2002 WS6, SLP lid
PostPosted: Sat Nov 07, 2009 7:08 am
Correct, but if that part still does not pass and you go over the 30 days they will reinspect the whole vehicle. I know from experience.
01 TA-M6-Blue
