It is currently Mon Aug 24, 2026 12:43 am
 Post subject: Where to get suspension work done?
PostPosted: Sun Dec 13, 2009 10:57 am
Well I was thinking to put some Eibash Springs and Bilstien shocks on my z28, but I dont know who in Germany is any good with them. I live in the Kaiserslautern area.
White 95 Z (Left rear corner smashed)
Working on building her from the ground up... end less pit of money
 Post subject: Re: Where to get suspension work done?
PostPosted: Sun Dec 13, 2009 12:20 pm
I guess you could check with Dany's place ... shouldn't take long to put the stuff in ...
PostPosted: Sun Dec 13, 2009 1:46 pm
I can do it if you are registered on base.
PostPosted: Wed Jan 27, 2010 7:13 pm
by registered on base, you mean what...?
got some strano springs coming with bilstein shocks
PostPosted: Wed Jan 27, 2010 8:14 pm
I mean that you have a USAEUR tagged vehicle and have access to Ramstein. However, I am very deep into my own projects now and will probably be too busy. We can try to work something out though.
PostPosted: Wed Jan 27, 2010 10:00 pm
yea, not a problem... springs probably wont be in for a few weeks, and who knows what my unit is doing then...
Got to put it in the body shop soon too :pat: ... among other things :mrgreen:
PostPosted: Mon Feb 01, 2010 2:16 pm
the hardest part is those front struts... The Strano/bilstein shocks are shorter than factory so make sure you have something to support the rear axle(or use the hub). The front isnt too bad and you can do it yourself with a tranny jack to support the A arms.
See it, Hear it, Feel it!!
PostPosted: Mon Feb 01, 2010 3:41 pm
Thanks, I hope I like them, I went with Eibash(pro street)/bilstein on my formula, and I loved the way it rode, I started listening to sam strano, and i figured I'd give his product a try, seems very educated, and not afraid to clarify misnomers... I had my Eibash put in at a exhaust shop in Cali, but I'm not familiar with the shops around Kaiserslautern.
PostPosted: Tue Feb 02, 2010 9:31 am
I'm sure you'll like them. I've got the Strano springs with Konis.
PostPosted: Tue Feb 02, 2010 11:34 am
Konis, very expensive... otherwise I would have...
PostPosted: Wed Feb 03, 2010 9:58 am
Yes, I know... I started with Koni/Bilstein combo with stock springs and switched to Koni/Koni with Strano springs last year.
PostPosted: Mon Feb 08, 2010 8:09 pm
Actually make that UMI K-Member & CM Adjustable A-Arms... Should be a good ride afterwards...
probably have a shop do that, because it will need to be aligned anyway...
PostPosted: Mon Feb 15, 2010 7:51 am
I recommend Phil's Garage over in Einseidlerhof. He knows what he's doing, does great work and speaks perfect english.
2008 Corvette Z51 M6
Black
2000 Camaro SS Conv. M6
*Sold*
