It is currently Sun Oct 18, 2026 11:34 am
 Post subject: Battery stuff
PostPosted: Wed Mar 03, 2010 10:43 am
Maybe someone here knows the answer.
I need a new battery and thought about trying a lightweight battery. When I look at this picture...
http://www.injuneer.com/images/photos/Engine/Braille.jpg
...I see some sort of "battery terminal adapters". But how exactly are they called and where can I get those?
 Post subject: Re: Battery stuff
PostPosted: Wed Mar 03, 2010 11:00 am
You may have problems with that battery with a heat soaked car or in 0 degree weather.
Check out this link from EDO USA
Rule of thumb is two CCA per cubic inch.
Also remember the lighter the battery the less amp hours you have. This will equate to how fast the battery will discharge when using accessories with engine off.
PostPosted: Wed Mar 03, 2010 11:32 am
I picked up a set of adapters to be able to use a standard European battery in my car in a pinch ... ran something like 5-10€ or so at M&F's ...
PostPosted: Wed Mar 03, 2010 3:49 pm
Garry: Thanks, found it.
Roy: Yeah I know those batteries have their drawbacks. I'm not sure... It's between 5 and 8 kg that I lose in the front of the car in a quite high position. Question is if I will ever "feel" that. Do you have experience with those (or similar) batteries from a driving dynamics point of view?
PostPosted: Wed Mar 03, 2010 4:09 pm
Keep in mind injuneer's car I believe is a track baby... he's pushing over 800 hp, and 1000 tq... (300 shot of nos tho I think)
I know he's voiced his complaints about the Red-Top not being able to withstand long periods of inactivity.
White 95 Z (Left rear corner smashed)
Working on building her from the ground up... end less pit of money
PostPosted: Wed Mar 03, 2010 5:57 pm
From a driving dynamics no, but then a a LS1 Fbody is pretty balance from side to side and cross corner.
Front to rear weight split is 56%/44%. So it is not to bad off.
PostPosted: Wed Mar 03, 2010 6:49 pm
If you're really concerned about weight and handling, then move it to the trunk; It's not that hard. You'll need an Optima unless you vent it outside somehow.
PostPosted: Wed Mar 03, 2010 7:15 pm
Odyssey is also a favorite for dry cell batteries, perhaps without the problems people experience with the yellow/red tops
PostPosted: Thu Mar 04, 2010 9:51 am
Thanks for your opinions... :)
PostPosted: Thu Mar 04, 2010 7:11 pm
I am in the Market also for a battery , will probably pick one up this weekend its in stock.
PostPosted: Fri Mar 05, 2010 9:42 am
And which one? :)
PostPosted: Fri Mar 05, 2010 10:27 am
Stock replacement from post . I believe its either by EverReady or Interstate.
