It is currently Wed Sep 09, 2026 12:27 pm
 Post subject: Exhaust adapter needed!
PostPosted: Fri Feb 04, 2005 10:07 am
Hey all...
I need an exhaust adapter to go from my Y - pipe (3") to 2 1/4" for my stock I pipe....something that I can remove when I get a full 3" I-pipe (later)
AAFES does not have one...maybe they have one down @ the KMC area.
2011 Chevy Camaro SS/RS
Sold my Bird to ChrisV6!
1998 Skyline GTS - SOLD!
PostPosted: Fri Feb 04, 2005 12:34 pm
Get a 2 1/4 pipe, and have the local craft shop expand one end to make it fit. That is too easy! :)
PostPosted: Sat Feb 05, 2005 8:09 am
you think you would get it to expand that far?
PostPosted: Sat Feb 05, 2005 8:16 am
Hm ... when I needed an adapter for the Jeep exhaust, a local car place (well, mainly for businesses, they carry stuff up to truck sizes and beyond) had dozens of different pipes ... with those sizes, I think regular car places will be a bit understocked ;) Check a truck supply place ... :)
PostPosted: Sat Feb 05, 2005 9:06 am
I heared there is a place in Siegelbach near K-Town which is specialized on exhaust pipes and welding of such ... not cheap though.
I will see if I can find out the address again.
Nice wheater, thought I take the T-Top for the shopping tour now the battery is dead... argh!
PostPosted: Sat Feb 05, 2005 10:06 am
Saw a guy in an open 'vert yesterday ... thick jacket, and most likely heater turned all the way up, as it was close to freezing ...
PostPosted: Sat Feb 05, 2005 10:43 am
I think so Roy, but I haven't actually seen it done. That's only 3/8ths of an inch all the way around. :? I guess it also depends on the pipe used.
PostPosted: Sat Feb 05, 2005 11:14 am
Thats as a good stretch, pipe would have to be very malleable.
PostPosted: Sat Feb 05, 2005 11:20 am
You're right. It might not be that easy. I'm just trying to put suggestions out there. :)
PostPosted: Tue Feb 15, 2005 3:27 pm
I've sent you a pm slick. You get it?
PostPosted: Tue Feb 15, 2005 6:16 pm
That sure wouldn't be hard from the guy at Kapaun
