It is currently Mon Aug 24, 2026 8:36 am
 Post subject: 1 Strong LS1
PostPosted: Thu Sep 01, 2005 2:57 pm
Nice motor and great pull.
http://www.neufamily.org/03vids/parishdynorecord.wmv
PostPosted: Fri Sep 02, 2005 6:33 am
D@mn ... Bruce, I guess that's the way for you ... 1000+hp/1000+tq, no nitrous ...
Wonder what he does at the track ...
PostPosted: Fri Sep 02, 2005 7:28 am
Usually a total different outcome because the vehicle has to actually work from a stop to get moving.
PostPosted: Fri Sep 02, 2005 8:41 am
And i wonder if the engine can handle 26psi longer than in a 10sec dyno pull... ;-)
PostPosted: Fri Sep 02, 2005 9:19 am
No need to, if he does 10s or less in the 1/4. 8)
PostPosted: Fri Sep 02, 2005 10:25 am
I saw a video of that truck running 10.50s @ 130mph. That was some shakedown passes on the new motor. I am sure it is faster now. It is a 4 wheel drive also. He used to run it on factory tires with the truck in 4WD. From the video you can see he is running Nitto drag radials on all 4 wheels now.
