It is currently Mon Aug 24, 2026 3:11 am
 Post subject: Dumb clutch question
PostPosted: Thu Dec 06, 2001 4:33 pm
OK, this may be completely dumb, but I will ask it anyway. OK, can you treat a clutch like brakes? Pull the clutch plate and sand the glaze off the PP, flywheel and clutch plate?
PostPosted: Thu Dec 06, 2001 6:38 pm
Well
It can be done , but as last ditch effort. The sanding on the fly wheel and p/p won't get rid of any glazing on there . As for the clutch disk it self . If it has slipped no amount of sanding will keep it from slipping again.
PostPosted: Fri Dec 07, 2001 6:34 am
Sounds like you're haveing a little trouble there Jessie?
