It is currently Mon Aug 24, 2026 11:46 pm
 Post subject: Recall LS1
PostPosted: Mon Feb 11, 2002 2:00 am
99-2000 Camaro,Firebird,Corvette w/ vin G or S engine.Subject:High oil consuption may be caused by faulty piston rings .Oil consumption may be one quart in 400 to 600 miles.The problem is found more often in cars w/ manuel transmissions where the engine is more likely to spend more time at higher rpm.New piston rings from kit #88894299 should be installed,but not the whole set.Install only the number 2 compression ring .Leave the the original number 1 compression ring and the oil ring rails on the pistons.Do not dress or hone the cylinder bore.Changing the original bore finish may make the problem worse.Bulletin 01-06-01-023.
Zac (The Virgin 97 TA)
PostPosted: Mon Feb 11, 2002 2:24 am
That would make me feel real good!!! NOT
I love GM
PostPosted: Mon Feb 11, 2002 7:25 am
Doesn't sound like a solution to me. It will probably have more wrong with it after they're done with it than before.
PostPosted: Mon Feb 11, 2002 4:46 pm
Especially over here, with Hans and Frans!! No offense to the Germans on the board, but they still have a lot to learn about these engines!! :)
PostPosted: Tue Feb 12, 2002 10:29 am
Here's the soloution get an LT1 engine... take out the oil burning LS1 nad install the LT1 for a greater motoring experiance! (Just kidding.... it does suck that the re-call came out over here... due to the fact that whenever I bring my car in for recalls they come out worse than when they went in!!!!!)
