It is currently Mon Aug 24, 2026 1:53 am
 Post subject: Sway Bars
PostPosted: Thu Jun 27, 2002 1:35 pm
Checking out prices for sway bars and they vary wildly from over $400 for Hotchkis down to BMR and Spohn etc. However, I stumbled across a 1LE 32/21 kit with full poly-bushing mounting kit for $199. Any reason why it's so much cheaper or should I buy it?
LCA's - any good reason for having adjustables. I can see why you'd want an adjustable Panhard bar but not the LCA's.
PostPosted: Thu Jun 27, 2002 5:10 pm
Get the 1LE! As for the LCAs, you really don't need adjustable, unless you are a real perfectionist, and use a lot of micrometry!! :)
