It is currently Tue Aug 25, 2026 4:49 am
 Post subject: LS1 - what gas do you get?
PostPosted: Thu Jul 10, 2003 1:09 pm
What do you fill your car up with:
Super or Super Plus?
I always used Super until recently, since then used Super Plus but didn't notice any difference...
PostPosted: Thu Jul 10, 2003 1:38 pm
Super Plus in the states, just Super here. I believe I have lost .00000001 HP Due to the change :lol:
PostPosted: Thu Jul 10, 2003 2:25 pm
Correct me if I'm wrong, but isn't the octane percentage in the states lower than here? That is, premium being about as high in octane as regular is here?
PostPosted: Thu Jul 10, 2003 2:39 pm
Super over here is actually around 90 "US" octane. Super plus will not make a difference unless you have increased your compresion ratio or advanced your timing to take advantage of the higher octane. Personally, I use super. Every 3rd tank in my '57 gets super plus or when I'm going to run it hard for an extended period on the 'bahn. :wink:
PostPosted: Thu Jul 10, 2003 5:40 pm
OK, well, I thought Super Plus cannot hurt since I'm going to the Ring quite frequently and I'm not cruising there... ;)
 Post subject: Super Plus
PostPosted: Thu Jul 10, 2003 6:07 pm
I use Super Plus, cause if I try to stick a different nozzle in her,.... she locks the gas cap shut!!!
PostPosted: Thu Jul 10, 2003 6:59 pm
I would recommend Super Plus. Detonation is a bad thing, especially in an aluminum engine and heads. The computer will probably take care of it, but it does it by cutting back on your timing a little bit which cuts power. Personally, I don't use anything but Super Plus in any of my cars. The price isn't that much difference and the super plus will give you a little extra mileage. Just my 2 cents worth.
PostPosted: Fri Jul 11, 2003 7:04 am
Super in the states is normally 90 octane
Super Plus is normally 93 or 92, depending on who you are buying from.
90 or above is a good thing!
PostPosted: Fri Jul 11, 2003 10:49 am
I thought the measurement for octane in the US is "MOZ" (Motor-...)
while in Europe it´s "ROZ" (Research-...) and there´s no real way to convert between them..? I get a bit confused with all the different names and octane numbers ;)
PostPosted: Fri Jul 11, 2003 1:01 pm
I think in the US they use (ROZ+MOZ)/2 while here in Germany/Europe we use just the ROZ...
PostPosted: Sun Jul 20, 2003 1:59 pm
I use super... superplus is not needed
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
PostPosted: Mon Jul 21, 2003 8:50 am
I only use the best fluids in my Z, i.e. Mobil1, Super plus, liqui moly, etc..... BTW, 95 octane here is equivalent to 98 in the states.
