It is currently Tue Aug 25, 2026 2:16 am
 Post subject: AC Compressor
PostPosted: Thu Oct 02, 2003 6:48 am
AC Compressor
The funny tapping that I have thought for some time might be a dodgy hydraulic tappet but then the main dealer said there was no fault found, well I listened to various parts of the engine and am almost convinced it's coming from the ac compressor but haven't found the time to take it off.
Firstly, as a matter of theory, if the compressor is seized, can the clutch thingummybob clatter away to itself like woody woodpecker? It's awkward to disconnect the belt as I can't see if it's the main belt or a separate belt behind.
How easy is the compressor to replace and how easy is it to remove all the ac altogether to get rid of some dead weight.
I should say the ac blows lukewarm. Can a duff compressor actually generate heat into the system?
 Post subject: Re: AC Compressor
PostPosted: Thu Oct 02, 2003 10:16 am
If your AC blows warm air, maybe it's lacking some refridgerant? The compressor will not start with the refridgerant level being too low.
PostPosted: Thu Oct 02, 2003 1:18 pm
No, I already had the thing recharged and there are no leaks so it's not that. :cry:
PostPosted: Thu Oct 02, 2003 3:07 pm
I just had the same ordeal...unhook the ac compressor. Their should be a little cannon plug on it. The clutch will engage and spin freely. If nothing is heard then its the compressor. I had the tapping noise and it turned into a squeaking belt. I disconnected and she runs like a champ minus the ac.
PostPosted: Tue Oct 14, 2003 9:00 am
zcam94, you're a bleedin' star, guvnor. This tapping has driven me mad for 18 months now and I was convinced it was a tappet or something. Nothing worse than a gruff V8 being drowned out by a loud tapping - sounded like a Mini A series engine.
Sure enough, I yanked the AC pump relay and whammo, the noise instantly vanished. God, that sounds good. Stuff the ac.
How easy or hard is it to replace the pump?
PostPosted: Sat Oct 25, 2003 7:30 pm
good stuff
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
