It is currently Mon Aug 24, 2026 10:55 pm
 Post subject: Strut Tower Brace fitted
PostPosted: Tue Dec 09, 2003 7:35 am
This is old hat for most of you, I know, but I fitted my BMR brace yesterday, fully expecting to be underwhelmed. However, instead I was amazed at the transfomation in the steering - sharper, more precise, more linear and tying the front end down to react as a single unit rather than like two different cars.
Can't believe I never did this before. Very recommended. And BMR have a sale on. 8)
PostPosted: Tue Dec 09, 2003 8:44 am
Yup, STB is a must ... along with all the other suspension stuff ... now if I were only able to do a AutoX with my 'vert ... (better yet, get the SFCs on and then do an AutoX run ;))
PostPosted: Tue Dec 09, 2003 1:29 pm
That was the most noticeable suspension mod that I made, by far!
PostPosted: Wed Dec 10, 2003 5:50 am
My BMR bar must be a dud , I didn't feel that :shock: :( :( :o :shock: :D
PostPosted: Wed Dec 10, 2003 7:30 am
Well, you also have a hardtop, Roy. I did my STB before the subframes, so that's why I noticed so much so fast.
PostPosted: Wed Dec 10, 2003 5:00 pm
Mine was the finishing touch so perhaps stiffening everything else made the front bit flex to compensate. Who knows but I'm definitely not imagining the improvement and I don't do slow. He he.
 Post subject: biggest add on
PostPosted: Mon Dec 15, 2003 6:50 am
The biggest suspension add ons that I noticed were my Kenny Brown SFC; BMR Extreme Strut Tower Bar; G-2 Adjustable A-Arms, G-2 Sway Bar, G-2 Pan Hard Bar, G-2 Lower Control Arms, G-2 Torque Arm; Eibach Springs; Bilstein Shocks. Of course I had them all put on in the same day, so that could be why they all seem to be the same. :?
PostPosted: Mon Dec 15, 2003 6:56 am
You better be able to notice something.
PostPosted: Mon Dec 15, 2003 10:43 am
My biggest bang for buck mod was the 555RII tires. There I could feel something like all the shortcomings in the rest of the suspension.
PostPosted: Mon Dec 15, 2003 4:18 pm
I have only heard good things about those tires Roy!
PostPosted: Thu Jan 01, 2004 8:23 pm
definitely... I am currently deployed and I keep slapping myself for not getting it done before....
and I have T tops, so it is a no brainer (slaps self)
I could have even get with Hawk....
(slaps self again)
note to self- (self, get a STB when you get back, idiot)
(slaps self silly) ...............
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
PostPosted: Thu Jan 01, 2004 8:39 pm
That will definitely help you on the track, Sven!
