 Post subject: max rpm's
PostPosted: Sat May 29, 2004 7:57 pm
I run mine @ max 7100 5th gear =185MPH maybe more can run 6000 5th gear about 160 MPH if the car is under load. 3000 is a good cruising RPM with power with power in 6th but I usually downshift to take care of high end cars.
PostPosted: Sun May 30, 2004 1:17 pm
Wow! Did you sell those springs to someone else man? I've tried to contact you several times, but with no response! :?
