 Post subject: new injectors
PostPosted: Sun Jul 18, 2004 8:11 pm
New injecters and fuel pump trying to feed this thing on crack. I currently have 36lbs injectors in there and it is not enough. Fuel pump is a 255 walboro from granatelli.
PostPosted: Sun Jul 18, 2004 9:44 pm
About time!!! I think that will help your problems.
PostPosted: Mon Jul 19, 2004 2:57 am
36 is more than enough if you go wet. seems your in uncharted territory when it coms to runninng a dry system
PostPosted: Mon Jul 19, 2004 4:51 am
So, all this time you've been knockin on the door of 10's.
Looks like you're ready to kick it down!
Give em hell!
PostPosted: Mon Jul 19, 2004 7:04 am
You didn't know an 11.2 was knocking on the door of 10s Jason. Tsk tsk tsk! :roll:
 Post subject: Re: new injectors
PostPosted: Mon Jul 19, 2004 7:30 am
Didn´t we talk about the fuel system and you said it´s big enough?
What happened that you changed your mind?
But keep those 36lbs injectors...FOR ME :twisted: .
Hehehehehehe. Please.
PostPosted: Mon Jul 19, 2004 3:42 pm
Did you see one of these at the end of that statement "?"?????
I think not. I was merely stating that he has been close.
Ass :P
PostPosted: Mon Jul 19, 2004 3:55 pm
Quit stating the obvious, Jason!
PostPosted: Tue Jul 20, 2004 9:07 am
If you go bigger before Oct on those injectors I want them! You still want the inline pump?
PostPosted: Tue Jul 20, 2004 3:11 pm
Someone has to help you out!
PostPosted: Sat Jul 24, 2004 4:55 pm
Bruce did you buy those 42lb from the mustang guy? What happened to the 36's if you did?
PostPosted: Sat Jul 24, 2004 5:36 pm
Yes I got the 42 lb injectors. Putting them in tomarrow The 36lb will be up for grabs for sale. Right now I plan on just the intank fuel pump.
PostPosted: Sat Jul 24, 2004 8:21 pm
How much for the 36's? I told ya I wanted them!
PostPosted: Sun Jul 25, 2004 8:26 am
I just sent you a PM John.
PostPosted: Sun Jul 25, 2004 6:41 pm
How do you know when you need to upgrade injectors?
PostPosted: Mon Jul 26, 2004 8:26 pm
power loss runs lean and pulls timing causing it to fall on its face and run 11.2
PostPosted: Mon Jul 26, 2004 9:00 pm
I'm just speaking in general, not specifically in regards to your application. :)
