It is currently Mon Aug 24, 2026 8:24 pm
 Post subject: wheel spin ?
PostPosted: Mon Mar 14, 2005 10:43 am
Over where I am at, many sections of road are grainy, and are of bad quality.
there are joints or sections of road that is very bumpy, almost in a state of disintegration.... due to the crumbly nature of the road.
When I first got here, whenever I gave anything close to half throttle, even in third gear, the tires would spin at will..... then if I got over a section of road that was not bumpy, the tires would hook up and I shot forward in Hyper Speed, instant 90 MPH.
The first couple weeks it ws fun, but I chilled because I wanted to take it easy on my driveline, including my differential.
My Trans Am LS-1 is kicking @ss and not missing a beat.
I keep the TCS on always, and I definitely need it.
1999 GM LS-1 T/A
2005 Suzuki GSX-R 1000
PostPosted: Mon Mar 14, 2005 10:50 am
I have high mileage tires, but you can see on them that the coarse nature of the road is rough on the rubber.
I am taking it much easier now, unless on a open, smooth highway, pretty much.
What are some problems that could arise if this situation went unchecked?
1999 GM LS-1 T/A
PostPosted: Sat Mar 19, 2005 8:03 am
well it really is not bad, just some sections of road actually
unless I am on a good with good asphalt quality, which hook up firmly.
It is common for me to just ever so slightly make the rear tires go just slightly faster than actual speed
I am definitely up to practice on rear end drift and steer now.
1999 GM LS-1 T/A
PostPosted: Sat Mar 19, 2005 8:46 am
Sounds like your bored.
PostPosted: Sat Mar 19, 2005 5:40 pm
yeah :(
1999 GM LS-1 T/A
