It is currently Mon Aug 24, 2026 11:46 pm
 Post subject: Installing FRCs ?
PostPosted: Wed Jun 28, 2006 7:56 pm
Stupid question - after trying to test-fit FRCs on my car I'm kind of puzzled - there seems to be lots of cables and lines in the way ... what all do I have to relocate to get them on???
PostPosted: Thu Jun 29, 2006 8:24 pm
You have to do a lot of trimming to get them to fit. They aren't even close as they are. The right side especially needs to be trimmed a lot. Hope this helps.
PostPosted: Thu Jun 29, 2006 9:03 pm
Can we take a look next weekend in Bitburg? Need to do some comparing, as at the moment I feel like I'd have about 1 square inch left after I'm done trimming ;)
Need to test-fit them, get the "changes" marked so I can get them painted ...
PostPosted: Thu Jun 29, 2006 9:26 pm
I took my FRC's off of the GTO because apparently in the 2004 GTO there is a rubbing issue on the fuel line. :?
PostPosted: Fri Jun 30, 2006 10:20 am
I've got a spare set of C5 FRCs if you want to have a spare set to test fit to make sure you don't mess up the good ones
PostPosted: Fri Jun 30, 2006 10:09 pm
Not a problem. If I can find some pictures of them off the car, I'll send them to you.
PostPosted: Fri Jun 30, 2006 10:26 pm
Tnx!
