It is currently Mon Aug 24, 2026 2:54 am
 Post subject: Firewall Grommet Location
PostPosted: Sun Aug 06, 2006 9:37 pm
I need to run a wire to the computer on my car for a shift light. Any idea where a grommet is located I could run the wire through. Without pulling most of the dash out, I haven't been able to find one. Appreciate any suggestions.
PostPosted: Mon Aug 07, 2006 3:48 am
Try the passenger side by the fan motor . That is where Val and I ran ours through for a shift light.
PostPosted: Mon Aug 07, 2006 8:11 am
Jerry,
If you drop the panel directly below the glove box you'll see the grommet (big one). As Roy said I've got wires for my shiftlight and line lock switch running through it.
Val
PostPosted: Mon Aug 07, 2006 10:24 am
I agree with Val and Roy on this one. Just take off the passenger side kick panel and the panel under the glove box. You may have to unbolt the computer under the hood and move it. That is where the gromet is located. I used a piece of lacing wire to pull my A/F wire through it. Good luck. BTW, are you going to Bitburg this weekend?
PostPosted: Mon Aug 07, 2006 7:54 pm
I found it. Thanks for the help. I just didn't look hard enough in the right place.
