It is currently Mon Aug 24, 2026 4:58 pm
 Post subject: reverse rotation waterpump ?
PostPosted: Fri Nov 17, 2006 8:04 pm
Is there a reverse rotation waterpump for the ls series ?
i looked a bit around , but couldn't find any info.
i might need to put my generator on the other side of the engine and change my whole belt thing....
Jeejee
PostPosted: Fri Nov 17, 2006 10:30 pm
Nope not that I know of
PostPosted: Sat Nov 18, 2006 9:41 am
They don't put LS1's in boats? That is normally were you can find a reverse rotating waterpump for a engine. When there is a dual engine setup normally one engine has to be counterrotating.
PostPosted: Sat Nov 18, 2006 5:09 pm
The lt1 has them
PostPosted: Sat Nov 18, 2006 7:17 pm
yes but i doubt it will fit :shock:
PostPosted: Sat Nov 18, 2006 7:39 pm
98 T/A raptor wrote:
The lt1 has them
Actually the LT1 is a reverse coolant flow system, where the coolant flows to the heads first then the cylinder block.
PostPosted: Mon Nov 20, 2006 3:45 pm
http://www.davedrive.com/v_2000_malibu_lx.htm
PostPosted: Mon Nov 20, 2006 4:02 pm
Get an electric and you don't have to worry about which way it rotates. It has an idler pulley built on the water pump so you can retain the factory belt configuration for a stock vehicle. I think Miezerie makes them.
