It is currently Mon Aug 24, 2026 11:10 am
 Post subject: PCV catch can?
PostPosted: Sun Sep 24, 2006 11:34 am
Anybody here put a PCV catch can on your motor yet? I read that some/most LS1 come up blowing varying amounts of oil in the TB ... causing intermittent KR and stuff ... guess I'm going to pick up a little fuel filter and some hose to put it in these days, see how much oil I come up with ...
PostPosted: Sun Sep 24, 2006 6:38 pm
Yep, got one myself. It does catch oil for sure. Not too much, but definitely some. Mine seems to burn more than it swallows through the can. Looks like maybe 100ml in 5000miles.
Try moving your fan temps down a fixed amount, that helps with KR too.
I think stock thermo will let you run at 90*C, I have a Hypertech 160 and run at 80*C all the time. So far around 6000miles no problem.
TAQuickness on ls1tech/efilive used to sell them, $30 I think with all the tubes and clamps required.
PostPosted: Sun Sep 24, 2006 7:26 pm
I moved the fan temp down a bit on the last couple tunes, #1 78 and #2 84 degrees ... down from 108/112 stock ...
PostPosted: Mon Sep 25, 2006 9:18 am
Garry, be carefull to use a filter with very little restriction, otherwise your engine might start to leak oil in places you never thought oil was in at the first place :wink:
PostPosted: Mon Sep 25, 2006 12:41 pm
If you want to fix a different way, swap the valley cover for the LS6 valley cover and you won't have that problem anymore. I was eating oil like it was going out of style due to the racing. I swaped the valley cover for a LS6 cover from Thunder Racing and 4 hours of work later problem solved!! If your going to do this talk to me first to make it easier for you, it's not just pull off & put the new one on.
PostPosted: Tue Sep 26, 2006 7:01 am
Mine is Val. :lol: If it is an LS6 block then you don't have to grind the lifter valley. I did notice though that the diamond pistons are scratching my cylinder walls just like they did on Bruce's motor. I am going to punch it .10 over in the states to clean it up.
PostPosted: Thu Sep 28, 2006 7:02 am
I did the grind thing and no more problems. If it's scratching the walls it's time to get some new ones!!
PostPosted: Sat Nov 25, 2006 1:42 pm
I use the AMW catch can works excellent.
Black Pontiac Trans Am WS.7- Runs on E85
And soon to be powered by Twin Turbos.
Hello from Sweden....
How to run your LS1 on E85
http://www.WS7.Runns.se
