It is currently Mon Aug 24, 2026 2:54 am
 Post subject: EFI Live questions
PostPosted: Fri Aug 31, 2007 10:52 am
On my 1998 LS1 Formula i changed some parts (heads, hotcam, etc.) I´m using Efi Live for tuning.
No i got from Roy (thank you for it) a custom tune from his 1998 camaro with near the same modification parts. The formula runs good with this.
No i have one problem. Always engine control lamp is on. It is writing: agr-problem. I don´t have an agr-valve. Can i programm it out with Efi Live? If yes, how can i find it?
Thanks for your help. I´m not very good in working with Efi Live.
PostPosted: Fri Aug 31, 2007 1:03 pm
Yes you can
JUst go under engine diagnostics > select "engine DTC MIL enablers"
Find P0400 thru P0405 and turn them off since you have no EGR.
PostPosted: Fri Aug 31, 2007 1:06 pm
perfect. Tank you Roy for the very fast and professionel answer.
I´m glad to have this forum :D
